KB91094
Published: October 24, 2025
AutoCorrect Tags results file from PAC Display fails to open in WordPad in Windows 11 version 24H2 and higher
PAC Display Configurator Basic
PAC Display Configurator Professional
All versions prior to R10.6a
R10.6a
If you are using Windows 11 version 24H2 or higher, the AutoCorrect Tags results file in PAC Display (Tools > AutoCorrect Tags) fails to open, and an error appears.
If you are using a computer that is running a lower version of Windows and has WordPad installed, the AutoCorrect Tags results file opens.
You can manually open the AutoCorrect Tags results file in NotePad by navigating to
C:\Users\<your username>\AppData\Local\Temp and opening the Opto<n> file (for example, Opto2).
