KB91102
Published: September 30, 2025
Unwanted "X-Priority:3" appears in the body of email sent by controller
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PACs:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1 (GEN2), SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
For groov EPICs: 3.3.0 to 3.6.0
For SNAP PACs: R10.5g
For groov EPICs: 4.0.0
For SNAP PACs: R10.6a
Adding a carriage return line feed character sequence (ASCII codes 13 and 10) to the end of the subject line (element 0 of the message body string table) may result in "X-Priority:3" being placed in the body of an email sent by the controller; however, if there is no carriage return line feed character sequence at the end of the subject, the email may be delivered with no body text.
While there is no workaround to prevent the controller from adding "X-Priority:3" to the body of an email, it is safe to ignore that text.
