KB91104
Published: February 26, 2025
EtherNet/IP Configurator does not upload SNAP-AOVA-8 module configurations
R3.0l to R3.0r
R3.0s
In Ethernet/IP Configurator, if you add a SNAP-AOVA-8 module to an I/O unit and configure its channels, then download the configuration, if you then upload the configuration to your computer, the SNAP-AOVA-8 module is missing.
After uploading the configuration to your computer, you can either:
  • If you retained the original configuration export file (.otg file), it can be used to download the configuration.
  • Manually add any SNAP-AOVA-8 configurations.
