KB91108
Published: May 1, 2025
Importing a variable file (.csv) with pointer table parameters into a strategy fails in PAC Control
PAC Control Basic
PAC Control Professional
All versions prior to R10.6a
R10.6a
When importing a variable comma-separated values (.csv) file that contains pointer table parameters into a strategy, you may receive an error in PAC Control. For example: The variable type could not be validated - PTR_TBL, PTR_TBL, B00ExternalVals, " ", ON_RUN, 512
