KB91122
Published: October 24, 2025
ENET2 disabled after firmware update
PAC Manager, when used with the following SNAP PAC R-series controllers:
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
R10.3a to R10.5c
R10.6a
After installing firmware on an R-series controller that had ENET2 configured and operating, ENET2 is disabled. (If you can physically look at the controller, you will notice that the indicator lights are off.)
After installing firmware, restart your R-series controller by either of these methods:
- In PAC Manager, send the Restart Device from powerup command (found in the Status Write > Operation dropdown list of the Inspect Opto 22 Device window) through the ENET1 interface.
- Cycle power.
