KB91180
Published: November 19, 2025
Size > “Height to Tallest” adjusts gadgets to shortest gadget
groov View running on the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
groov View running on the following groov Server for Windows:
groov View running on the following groov products (please note that Opto 22 no longer ships updates for these products):
  • GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.6.0 to 4.0.2 (may affect lower versions)
All other products: R4.5c to R4.5d (may affect lower versions)
GRV-EPIC-PR1, GRV-EPIC-PR2: 4.0.3
All other products: R4.5e
In Build mode, when you select a group of gadgets and then right-click to select Size > Height to Tallest, groov View should adjust the height of all the gadgets in the group to match the height of the tallest gadget. With this issue, groov View sets it to the shortest gadget.
Manually adjust the height of each gadget.
