KB91222
Published: June 20, 2025
Some pages in groov Manage display "server offline" message
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
4.0.0
4.0.1
Depending on the time zone setting on your groov EPIC or RIO, you may see a Server Offline - Data May Be Stale message (on a red background) at the top of the following groov Manage pages:
  • About
  • Node-RED Status
  • groov View Status
  • Data Service
Change the time zone settings:
  1. From the groov Manage Home page, click Settings > Time.
  2. In the Time Zone section, click Region and select one of the following:
    • Universal
    • America—If you select America, click Locality and choose one of the following zones closest to your location: Los Angeles, Denver, Chicago, or New York.
    • Etc—If you select Etc, click Locality and choose a zone that starts with GMT. Important: Make sure you understand the sign (postive or negative) of your selected zone; the signs are reversed from the standard ISO 8601 convention. For more information, review the "Area" sub-section of the Names of timezones article.
  3. Click Set Zone.
