KB91223
Published: October 7, 2025
Using 'Receive String Table' to read from a file may return -39 (timeout error)
Firmware for the following:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
R10.5g
R10.6a
The PAC Control Receive String Table command should return a status of 0 (success) when reading from a file if the command specified more elements than were in the file. However, when this issue is present, it will return a -39 (timeout) error.
When you specify a value for the Length argument, ensure it is less than or equal to the number of elements in the file.
