KB91226
Published: June 3, 2026
POSTs to the SNAP PAC REST API may fail when the closing bracket is on a different line than the data
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SoftPAC
All versions prior to R10.7a
R10.7a
When attempting to send a POST to the SNAP PAC REST API, the POST may fail if the closing bracket is on a different line from the data. For example:
"value":"string"
or
{"value":"string"
Ensure the closing bracket is on the same line as the data in the POST. For example:
{"value":"string"}
or
"value":"string"}
