KB91228
Published: August 21, 2025
groov EPIC's LCD becomes unresponsive when external monitor is connected
- GRV-EPIC-PR1
- GRV-EPIC-PR2
4.0.0 to 4.0.1
4.0.2
When you connect an external monitor to a groov EPIC's HDMI port, the EPIC's LCD screen may go blank and becomes unresponsive. You are more likely to encounter this issue if you connect a Sceptre 20" 1600x900 75Hz Ultra Thin LED monitor.
Cycle power to the groov EPIC.
