KB91235
Published: January 12, 2026
Addresses copied from the PAC Manager Inspect window may not paste correctly in the Generic Read/Write page
PAC Manager
All versions prior to R10.6b
R10.6b
In PAC Manager, if you copy an address (like F026 0000) from the Inspect Opto 22 Device window (such as from the Analog Bank page) and paste it into the Address 0x FFFF field on the Generic Read/Write page (Other > Generic Read/Write), the address may be changed. For example, if you paste F026 0000, it may change to 0000F026.
When copying/pasting an address in PAC Manager, remove any spaces and ensure that 8 hex characters are used.
