KB91252
Published: August 21, 2025
Ignition may not start
Firmware for GRV-R7-MM2001-10
4.0.0 to 4.0.1
4.0.2
When you try to enable Ignition or Ignition Edge, you may observe the following:
  • Ignition may not start.
  • If Ignition does start, and then you restart your RIO, Ignition may not start.
This is more likely to happen if you enable the CODESYS controller.
For help with a workaround, contact Opto 22 Product Support Group by emailing support@opto22.com.
