KB91261
Published: August 21, 2025
groov Manage incorrectly reports Ignition 8 as disabled
Firmware for GRV-R7-MM2001-10
4.0.0 to 4.0.1
4.0.2
When you enable Ignition or Ignition Edge, after the progress message closes, the Status section continues to indicate that your selected platform is disabled even though the Enable switch in the Config section is set to enabled.
Wait another thirty seconds after the progress message closes, then refresh the groov Manage Ignition page by either refreshing the page or navigating away from the page and returning to the page.
