KB91262
Published: August 21, 2025
Port Redirect configuration not restored after power cycle
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
4.0.0 to 4.0.1
4.0.2
If port redirection is configured, and later power is cycled or you restart the unit using groov Manage, the configuration is lost.
