KB91264
Published: December 15, 2025
Resizing the Configure Power Monitoring Module dialog box in PAC Control may cause appearance issues
PAC Control Basic
PAC Control Professional
R10.5a to current
If you resize the Configure Power Monitoring Module dialog box when configuring a GRV-IVAPM-3 or GRV-R7-I1VAPM-3 module in PAC Control, you may encounter appearance issues.
Do not resize the dialog box.
