KB91270
Published: August 21, 2025
Port redirect configuration disappears after updating firmware or restoring a backup
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
All versions prior to 4.0.2
4.0.2
If you perform a firmware update with Backup Settings enabled or restore a backup, the port redirect configuration and rules are lost.
