KB91274
Published: August 21, 2025
In Ignition, dragging a tag into the Tag Browser changes status to Uncertain_LastKnownValue
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for GRV-R7-MM2001-10
4.0.0 to 4.0.1
4.0.2
In Ignition, when you drag a tag with a known good quality to the Tag Browser, the quality of the tag may change to Uncertain_LastKnownValue. If you review the wrapper logs, you may find messages similar to the following:
java.lang.InternalError: a fault occurred in a recent unsafe memory access operation in compiled Java code
    at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:136)
    at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:788)
    at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:724)
    at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:650)
    at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:562)
    at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:994)
    at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
    at java.base/java.lang.Thread.run(Unknown Source)
Contact Product Support (by email, support@opto22.com) for instructions on a workaround.
