KB91298
Published: November 19, 2025
PAC Control "Convert Number to String Field" command incorrectly assigns asterisk to string variable
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
4.0.1 to 4.0.2
4.0.3
In PAC Control, the Convert Number to String Field command correctly assigns an asterisk to a string field when the length of the string field is smaller than the length needed. However, with this issue, the command assigns an asterisk to the string field even if the length of the string field is large enough.
