KB91301
Published: January 12, 2026
Grouped line objects in PAC Display may not change color as expected
PAC Display Runtime Basic
PAC Display Runtime Professional
All versions prior to R10.6b
R10.6b
If you have a grouped set of line objects in PAC Display Runtime that are configured to change to the color black (RGB=0,0,0) based on a tag value, the grouped objects may not change color until the window is resized.
Instead of having the grouped line objects change to pure black (RGB=0,0,0), have them change to a similar shade of black (RGB=1,1,1).
