KB91304
Published: June 3, 2026
Digital TPOs start operating upon I/O unit boot-up or after restart
Firmware for the following EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following RIOs:
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
Firmware for the following SNAP PACs:
  • SNAP-PAC-EB1, SNAP-PAC-EB1-FM, SNAP-PAC-EB1-W
  • SNAP-PAC-EB2, SNAP-PAC-EB2-FM, SNAP-PAC-EB2-W
  • G4EB2
  • SNAP-PAC-SB1, SNAP-PAC-SB2
For groov EPICs: 3.2.1 to 4.0.2
For groov RIOs: 3.2.0 to 4.0.2
For SNAP PACs: R8.2a to R10.6b
For groov EPICs: 4.0.3
For groov RIOs: 4.0.3
For SNAP PACs: R10.7a
After an I/O unit boots up or restarts, any I/O configurations stored in persistent memory are restored. If a TPO is restored, the TPO should not start controlling the digital output, but with this issue, it may.
Disable TPOs (by turning off the digital output or setting the TPO Percent to 0) before storing I/O configuration to persistent memory.
