KB91314
Published: July 30, 2026
OptoScript blocks in PAC Control may be missing the Pointer Variable type in the Select Variable dialog for subroutines
PAC Control Basic
PAC Control Professional
All versions prior to R10.6c
R10.6c
When attempting to create a local pointer variable in a subroutine using an OptoScript block in PAC Control, the Pointer Variable option may be missing from the Type list in the Select Variable dialog box.
Use action blocks or manually type the OptoScript.
