KB91340
Published: March 2, 2026
Touching EPIC touchscreen when in sleep mode may trigger unintended UI response
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 4.1.0
4.1.0
With a typical touchscreen, when you touch a blank screen, the only behavior should be that the screen comes on. However, with this issue, the touch may trigger a UI item located at the spot where you touched the screen, which may create unintended consequences.
