KB91345
Published: August 26, 2026
mDNS/Bonjour hostnames only register after restart
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
4.0.0 to 4.1.2
4.1.3
EPIC and RIO should automatically register a Multicast DNS (mDNS)/Bonjour hostname when you change your device’s hostname. With this issue, your EPIC or RIO does not register the mDNS/Bonjour hostname until you restart it.
Restart your EPIC or RIO with any of the following options:
- In a browser, connect to the device using its IP address, then log into groov Manage and click System > Restart.
- For EPICs, if you have physical access to the processor, use the touchscreen to log in, then tap System > Restart.
- Cycle power:
- For EPICs, if you have physical access to the processor, you can turn the power button off, wait 10 seconds, then turn it on.
- For RIOs, if you have physical access to the module, you can try one of the following:
- If connected via Power over Ethernet (PoE), disconnect the Ethernet cable, wait 10 seconds, then connect it.
- If connected to a separate power supply, disconnect the power supply, wait 10 seconds, then connect it.
