KB91353
Published: June 3, 2026
If I/O unit on redundant network is available, IsIoUnitReady and IsIoUnitCommEnabled commands may return false
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following SNAP PACs:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
For groov EPICs: All versions prior to 4.1.0
For SNAP PACs: All versions prior to R10.7a
For groov EPICs: 4.1.0
For SNAP PACs: R10.7a
If your PAC Control strategy works with a SNAP I/O unit configured with redundant Ethernet links, when communication is lost on the primary Ethernet link and the secondary Ethernet link becomes active, the Is I/O Unit Ready? and Is Communication to I/O Unit Enabled? commands may return FALSE.
