KB91354
Published: January 12, 2026
PAC Display Configurator program icon may be indistinguishable from PAC Display Runtime program icon in Windows
PAC Display Configurator Basic
PAC Display Configurator Professional
R10.6a
R10.6b
The program icon for PAC Display Configurator may appear the same as the program icon for PAC Display Runtime in Windows File Explorer and the Windows Taskbar, making them indistinguishable from each other.
Configure a custom icon for the PAC Display Configurator shortcut:
  1. Open the PAC Project 10.6 folder on your desktop (the folder is saved there by default when you installed the program).
  2. In the folder, right-click PAC Display Configurator 10.6.
  3. Select Properties from the pop-up menu.
  4. In the Properties window, click Change Icon on the Shortcut tab.
  5. Select an icon from the list and click OK.
  6. Click Apply. If you are prompted for administrator permissions, click Continue.
  7. Click OK to close the Properties window. The PAC Display Configurator icon changes to the one you selected.
