KB91360
Published: January 12, 2026
The minus (-) character may not be accepted in the Initial Value field when adding or editing integer or integer table variables in PAC Control
PAC Control Basic
PAC Control Professional
R10.6a
R10.6b
When adding or editing integer or integer table variables (32-bit and 64-bit) in PAC Control, you may not be able to type a minus (-) character for a negative value into the Initial Value field of the Add Variable or Edit Variable dialog windows.
Paste the negative value with the minus (-) character into the Initial Value field instead of typing it.
