KB91408
Published: July 30, 2026
Find & Replace Tag in subroutine replaces substring globally rather than locally
PAC Control Basic
PAC Control Professional
R9.4a to R10.6b
R10.6c
If you are in a subroutine and choose Edit > Replace and then choose Tag in the Search For field in PAC Control, the replacement may not occur locally within the subroutine, as expected. Instead, the tag substring in the parent strategy is replaced (a global rather than a local scope).
Modify subroutine tag names one at a time, or use the Find & Replace option in the OptoScript block editor for each block of OptoScript in the subroutine.
