KB91414
Published: April 1, 2026
When Node-RED and groov View (groov EPIC only) are disabled, Uptime and Last Started fields in groov Manage display incorrect values
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
4.0.0 to 4.1.0
4.1.1
When Node-RED and groov View (groov EPIC only) are disabled, the Uptime and Last started fields on their respective groov Manage pages may display incorrect values. For example, the Uptime field may incorrectly display 56 years, while the Last started field may incorrectly display a date from 1969 or 1970.
When Node-RED and groov View are disabled, ignore the values in the Uptime and Last started fields on their respective groov Manage pages.
