KB91418
Published: April 1, 2026
Node-RED on groov devices running pre-4.0 firmware may encounter memory leaks and restarts when accessing groov devices running 4.1.0 firmware with new web server certificates
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
All versions prior to 4.0.0 to 4.1.1
4.1.1
When groov Manage is used to create new web server certificates on devices running firmware 4.1.0 and higher, it may cause Node-RED on groov devices running firmware 3.6.1 and lower to unexpectedly restart or experience memory leaks. This occurs when using Opto 22 nodes (node-red-contrib-pac, node-red-contrib-groov, and node-red-contrib-groov-io) to access data from the groov devices running firmware 4.1.0 or higher.
This issue is related to known Node.js bugs. For more information, see tickets 37757 and 37990.
Upgrade any groov devices running firmware versions 3.6.1 and lower to firmware version 4.0.0 or higher.
