KB91428
Published: April 1, 2026
A Node-RED Dashboard UI-only user can't access the Node-RED dashboard
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
4.1.0
4.1.1
If you create a FlowFuse Dashboard (also known as the Node-RED Dashboard 2.0) and a Node-RED Dashboard UI-only user, when the user logs in and attempts to view the dashboard, groov Manage displays the login screen instead of the dashboard.
If possible, change the Node-RED user's permission from Dashboard UI to Editor.
