KB91438
Published: July 30, 2026
Not all SNAP-IDC5Q points appear in the PAC Control Inspect I/O Unit dialog
PAC Control Basic
PAC Control Professional
All versions prior to R10.6c
R10.6c
When inspecting an I/O unit in PAC Control Debug mode, only the first point of a SNAP-IDC5Q module may appear on the Points [Detailed] and Points [Compact] tabs of the Inspect I/O Unit dialog (double-click the I/O unit from the Strategy Tree).
This is a cosmetic defect, and you can access all points of the module from the Strategy Tree.
