KB91455
Published: August 26, 2026
No indication when components in backup file fail to restore
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
4.0.0 to 4.1.2
4.1.3
When you are restoring from a backup file, it's possible that the overall restoration process finishes, but one or more components may not have been restored successfully. groov Manage should show you a message indicating which components were not restored successfully and prompt you to reboot. With this issue, groov Manage does not display the message notifying you which components were not restored and the need to reboot.
If you can connect to your EPIC or RIO from a browser, enter the following URL: https://device-hostname/commissioning/loading.html, where device-hostname is the hostname of your EPIC or RIO. From this page, you can identify which items failed to restore correctly and restart your device.
