KB91515
Published: June 15, 2026
“Fragnesia” Vulnerability in groov EPIC and RIO
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
4.0.0 to 4.1.1
4.1.2
The “Fragnesia” vulnerability in the Linux kernel in groov EPIC processors and groov RIO modules could be exploited by an attacker to obtain unauthorized administrative (or root-level) privileges to your EPIC or RIO by crafting specific logic through these applications:
  • Node-RED
  • CODESYS
  • Shell access (SSH)
This vulnerability is identified in the National Vulnerability Database as: CVE-2026-46300
Your groov device is designed with several cybersecurity features to help prevent unauthorized users from accessing your device and to protect the services that run on it, like groov Manage, Node-RED, CODESYS, or shell (SSH). The following cybersecurity features offer the highest level of protection when implemented with the described best practices:
  • Accounts—Always create cryptographically strong, unique passwords for all user accounts, and protect these account credentials. When you first started using your groov device, you created an administrator account. You are responsible for protecting this account, along with any subsequent accounts you may have created. (Remember: There is no default user account).
  • Firewall Configuration—The default firewall configurations on a groov device provide limited access to the services that run on it. If you change the default configurations, ensure that they restrict access from untrusted networks. For instructions on configuring the firewall, review the section “Configuring the Firewall” in the following user guides:
  • Network Zoning—The network interfaces (ETH0/ETH1, WLAN0, and VPN0) on a groov device do not communicate with each other, which helps support network zoning: dividing OT networks (which typically do not have internet access) from IT networks (which typically do have internet access).
If you believe your implementation of these cybersecurity features might have been compromised (thereby exposing your groov device to this vulnerability), you should implement the following mitigations:
  • If you’re not using Node-RED, disable it. To disable Node-RED:
    1. Log into your groov device with a user ID that has administrator privileges.
    2. In the groov Manage Home page, click Node-RED.
    3. In the Runtime field, click Disable.
    4. groov Manage prompts you to confirm that you want to disable Node-RED. Click OK.
    5. Wait for the Status field to display Disabled to ensure Node-RED is disabled.
  • If you're not using CODESYS, disable it. To disable CODESYS:
    2. In the groov Manage Home page, click Controller.
    4. groov Manage prompts you to confirm that you want to disable CODESYS. Click OK.
    5. Wait for the Status field to display Disabled to ensure CODESYS is disabled.
  • If you are using shell (SSH) access, do one of the following:
    • In shell, prevent loading of the esp4 and esp6 kernel modules. Contact Product Support for instructions.
    • Disable shell (SSH) access:
      2. From the groov Manage Home page, click System > Shell.
      3. If shell access is enabled, enter your shell username and password, then click Disable.
