KB91516
Published: August 25, 2026
NGINX Vulnerabilities in groov EPIC and RIO
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
All versions prior to 4.1.3
4.1.3
There are 4 different vulnerabilities in the NGINX software—which Opto 22 uses for user authentication—that could be exploited (when used in combination) by an unauthenticated attacker to remotely execute code:
Opto 22 has reviewed its product set for exposure to these vulnerabilities and determined that this vulnerability is restricted to users who have enabled Secure Shell (SSH) and manually modified NGINX configuration files or deployed custom web apps through the Linux shell.
If you used shell access to modify the configuration of NGINX, review any modifications made to the following modules and update them if they make these vulnerabilities exploitable:
- ngx_http_rewrite_module
- ngx_http_scgi_module
- ngx_http_uwsgi_module
- ngx_http_ssl_module
- ngx_http_charset_module
