KB91532
Published: August 26, 2026
After switching "Enable USB" to disabled, the USB port remains enabled
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
4.1.0 to 4.1.2
4.1.3
If Automount is enabled in groov Manage and you change the Enable USB setting to disabled, the setting appears disabled, but the port remains enabled and accessible.
Do not attach any USB devices to the port.
