KB91585
Published: October 12, 2026
PAC Display Configurator may crash when configuring an alarm point
PAC Display Configurator Basic
PAC Display Configurator Professional
R10.0a to R10.6c
R10.6d
After selecting an alarm point in the Graphic Dynamic Attributes dialog box and checking Alarm Point from the Control Engine Driven list, PAC Display Configurator may crash.
Use the older Dynamic Attributes dialogs for configuring alarm points. To enable the older dialogs for PAC Display:
- In PAC Display Configurator, go to File > Configurator Options.
- Check the Use Older Dynamic Attribute Dialogs option and click OK.
- Configure alarm points as needed.
Once you are done configuring the alarm points, repeat these steps to uncheck the
Use Older Dynamic Attribute Dialogs option. For more information, see the
PAC Display User’s Guide (form 1702).
