KB91609
Published: October 12, 2026
The “Set I/O Unit Scratch Pad Integer 64 Element” command in an action block may cause error -95 in PAC Control
PAC Control Basic
PAC Control Professional
All versions prior to R10.6d
R10.6d
When running a strategy that has the “Set I/O Unit Scratch Pad Integer 64 Element” command in an action block, you may see error -95 (“Data stack is not empty”) in the PAC Control message queue.
To use the “Set I/O Unit Scratch Pad Integer 64 Element” command, remove it from the action block and add it to an OptoScript block.
