KB91610
Published: October 30, 2026
GRV-OVMAILP-8 modules may reset at high temperatures
Firmware for GRV-OVMAILP-8
All versions prior to 1.3e
1.3e
The GRV-OVMAILP-8 module may reset at high temperatures.
When assembling the hardware:
- Ensure the chassis you are using is oriented correctly. Mount the chassis horizontally against a flat, vertical surface (such as a wall or panel). In this orientation, the module numbers are right-side up, the natural convection heat dissipation vents are along the bottom (facing the floor or the bottom of the panel), and the groov EPIC’s LCD display is facing straight out from the vertical surface. For more information, see the groov EPIC Chassis Data Sheet (form 2247).
- Do not place multiple GRV-OVMAILP-8 modules in adjacent slots on the chassis. Space them out on the chassis if possible.
