INPUT SWITCH
INPUT SWITCH
$48.50 (USA and Canada only)
G1 Digital Input Switch, 5, 15, or 24 VDC Logic
G1 I/O family
The input test module simulates an input on an I/O mounting rack. Each module contains a toggle switch that closes a contact on the logic side of the module. An internal resistor limits the current through the switch contact and provides a load similar to an actual module. The module works with logic voltages of 5, 15, and 24 volts. Internally, there is no connection to the field input terminals.
The input switch module is ideal for simulating external discrete events in order to test application software.
Agency Approvals: RoHS, CE; UKCA
Standard Digital Input Test Module Data Sheet
The input test module is a device that simulates an input on an I/O mounting rack ideal for simulating external discrete events in order to test the application software.
