SNAP-PAC-SB1
SNAP-PAC-SB1
$995.00 (USA and Canada only)
OBSOLETE SNAP PAC Serial Brain, analog/digital, with high-speed digital functions
NOTE: This product is obsolete and no longer available.
The SNAP-PAC-SB1 brain is an I/O and communications processor for your SNAP PAC System. Designed primarily to work in distributed systems controlled by a SNAP PAC S-series controller, the SNAP-PAC-SB1 provides local intelligence that frees the controller for supervisory tasks.
As an I/O processor, the SNAP PAC brain independently handles functions such as latching, counting, thermocouple linearization, watchdog timers, and PID loop control. These functions continue to work on the brain even if communication with the SNAP PAC controller is lost.
The SNAP-PAC-SB1 brain supports all the SNAP I/O analog and digital input and output modules available on the Opto 22 website. These modules can all be mixed on the same mounting rack and placed in any position on the rack. The brain and modules mount on a SNAP PAC rack, which holds up to 4, 8, 12, or 16 modules.
In addition to I/O processing, the SNAP-PAC-SB1 brain communicates over an RS-485 serial network (2-wire or 4-wire), and multiple SB-series brains can be installed in a multi-drop (daisy-chain) configuration.
The SNAP-PAC-SB1 brain offers high-speed digital functions, including high-speed counting (up to 20 KHz), quadrature counting, pulse generation and measurement, and TPO (time-proportional output). If you do not need high-speed digital functions, choose the SNAP-PAC-SB2 brain instead. For a complete list of features and specifications, see form #1689, the SNAP PAC Brains Data Sheet, under the Documents tab.
Ethernet and Serial Brains [Ethernet Brains are Obsolete 3/1/22]
Power Requirements
5.0–5.2 VDC at 750 mA maximum (does not include module power requirements)
-W Models: 5.0–5.2 VDC at 1.0 A maximum (not including module requirements)
Memory
16 MB RAM
Backup battery for real-time clock
Rechargeable (recharges whenever the brain has power). 5-year life when power is off (replacement part number: SNAP-PAC-BATTERY-ML2430). (Models manufactured before August 2007 have a 3-volt CR2032 lithium battery, available in retail stores. See original user guide for replacement steps.)
Hold-down screw
Torque: 8 in-lb (0.9 N-m)
Operating Temperature
-20 to 60 °C
Storage Temperature
-40 to 85 °C
Humidity
Agency certifications
-EB models (except -EB-W): UL, CE, RoHS, DFARS; UKCA
-EB-W models: UL, DFARS, UKCA; U.S., FCC Part 15 Subpart C; Canada, IC RSS-210
-SB models: CE, RoHS, DFARS; UKCA
-FM models only: Factory Mutual approved
Ethernet Brains (EB) only
Wired Ethernet Net­work Interfaces
IEEE 802.3 network, 10Base-T and 100Base-TX. Automatic MDC/MDI-X crossover (Ethernet crossover cable not required for direct connection to PC). Two switched interfaces, allowing multi-drop (daisy-chain) or standard star network configuration.
100 meters with Category 5 or superior UTP
Wireless LAN interface*
  Topologies
  Security
  Frequency 802.11a
  Frequency 802.11b/g
  Transmit Power
  Antenna Connector
  Roaming
Separate IP address
Infrastructure, Ad-Hoc
802.11i: AES - Compatible with WPA2 Personal, TKIP - Compatible with WPA Per­sonal, WEP. Note: TKIP/AES security is not supported in Ad-Hoc mode.
5.180–5.24 GHz, 5.745–5.825 GHz
2.412–2.472 GHz, 2.484GHz
15 dBm maximum
Reverse polarity SMA (RP-SMA or RSMA)
Supported within an SSID (Service Set Identifier) only
Serial Brains (SB) only
Network interfaces
RS-485, 2- or 4-wire, twisted pair(s), with shield
Serial data rates
300 baud to 230.4 Kbaud
Range: Serial multidrop
32 stations maximum on a segment (including PC, controller, repeaters, and I/O units); up to 3000 ft (914 m) on a segment
Connector screw
Torque: 1.7 in-lb (0.19 N-m)
* Requires Wired+Wireless model (SNAP-PAC-EB1-W or SNAP-PAC-EB2-W)
This guide is a comprehensive introduction to the SNAP PAC System. The guide describes the system's components (software, controllers, I/O processors, and I/O); shows how to build a basic system and how to expand it; and includes installation instructions, wiring diagrams, dimensional drawings, and specifications for parts.
NOTE: Due to the unavailability of essential parts, SNAP PAC brains are obsolete and no longer available. Instead of Ethernet-based brains, use a SNAP-PAC-R1 controller/brain; it has all the same features plus additional power (and programmability, if you need it). For serial brain options, contact Opto 22 Product Support.
SNAP PAC brains are powerful and versatile I/O and network communications processors. Designed primarily to work in distributed systems controlled by a SNAP PAC controller, SNAP PAC Ethernet brains can also be used as intelligent remote I/O for groov EPIC systems and Allen-Bradley Logix-based PLC systems.
SNAP PAC brains provide local intelligence for functions such as latching, counting, thermocouple linearization, watchdog timers, and PID loop control.
This document covers the following SNAP PAC brains:
SNAP PAC Controller and Brain Comparison Chart
This document compares features of SNAP PAC hardware controllers (SNAP PAC S-series and R-series) and SNAP PAC brains, all part of the SNAP PAC System.
NOTE: Due to the unavailability of essential parts, all SNAP PAC brains are obsolete and no longer available. Use rack-mounted controllers instead of Ethernet-based brains. For serial brain options, contact Opto 22 Product Support.
SNAP PAC System Product Guide
This README file lists revision changes made to the firmware used in SNAP PAC S-series, R-series, and SoftPAC controllers; SNAP PAC EB-series and SB-series brains; and G4EB2 and G4D32EB2 brains.
SNAP PAC I/O Coprocessor Firmware README
This README file lists changes to the I/O coprocessor firmware available in rack-mounted Opto 22 controllers and brains manufactured starting in 2016.
I/O coprocessors can be present in the SNAP PAC R-series controllers, and in SNAP PAC EB-series and SB-series brains. Instructions to find out if your device has an I/O coprocessor are included in this README and in the PAC Manager User's Guide.
NOTE: The following products manufactured with I/O coprocessors have firmware R3.0a; you do not need to update the firmware in these products at this time:
  • SNAP-PAC-EB1
  • SNAP-PAC-EB1-W
  • SNAP-PAC-SB1
  • SNAP-PAC-SB2
If you are using SNAP PAC controllers and SNAP PAC brains only, use Form 1704, PAC Manager User's Guide instead of this guide.
This guide shows you how to use PAC Manager to assign IP addresses, configure I/O, and inspect and maintain Opto 22 SNAP PAC hardware. PAC Manager is part of the PAC Project Software Suite and also available separately (part number PACMANAGER).
NOTE: If you are using older Opto 22 hardware in addition to SNAP PAC controllers and brains, use the Legacy Edition of this guide, form #1714.
SNAP PAC Brains User's Guide
NOTE: Due to the unavailability of essential parts, all SNAP PAC brains (EB-series) are obsolete and no longer
SNAP PAC brains, one of the four components of the SNAP PAC System, provide I/O processing and network communications for your distributed SNAP PAC System. SNAP PAC Ethernet brains can also be used as intelligent remote I/O in a groov EPIC system or an Allen-Bradley Logix-based PLC system.
This guide shows you how to install and use all SNAP PAC brains:
OptoMMP Protocol Guide
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
Replacing the SNAP PAC Rechargeable Battery Technical Note
Several SNAP PAC controllers and brains contain a rechargeable backup battery. The battery recharges whenever the brain has power and retains data for an extended period of time with the power off.
You should never have to replace this battery, but if you do, this technical note shows you how.
Quick Guide: Troubleshooting Info from SNAP PAC Systems
This technical note provides a quick guide about diagnostic files to collect and send in to Opto 22 Product Support for analysis when troubleshooting a SNAP PAC System.
Updating the Loader on a SNAP Device
It is rarely necessary to update the loader in a SNAP PAC controller or brain, but if you need to, this document shows you how. If you have questions, contact Opto 22 Product Support.
I/O Solutions for Temperature Monitoring (Chinese)
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Firmware for all SNAP PAC products (single download)
See the README document for information on changes and fixes in the current version of this product's firmware.
NOTE: Opto 22 recommends that you always use the most recent release of PAC Manager. Depending on the shipment date or the version number of the firmware currently installed on your SNAP-PAC-R or SNAP-PAC-S controller, older versions of PAC Manager cannot install certain levels of firmware:
  • As of February 22, 2022, some SNAP-PAC-R and SNAP-PAC-S controllers ship with new Ethernet components, along with PAC Firmware R10.4d (or higher) and new bootloader firmware to support the new components. PAC Firmware R10.4d (or higher) will not permit installing firmware lower than R10.4d on these controllers. To update firmware on these controllers, you need PAC Manager R10.4c or higher.
  • Effective April 2, 2018, some SNAP PAC controllers and brains have new flash components. These units shipped with firmware R9.5g (or higher) and new bootloader firmware. PAC firmware versions R9.5f and lower are not compatible with the new component. If you inadvertently install firmware R9.5f or lower on one of these units, you can recover by using the Failsafe Bootloader Mode to install firmware R9.5g or higher.
    • For more information about the new flash component, see KB87213.
    • For details on Failsafe Bootloader Mode, see "Replacing Damaged Firmware" in the PAC Manager User's Guide (form 1704).
  • To install PAC firmware R9.2c or higher on the following controllers only, use PAC Manager R10.4b (or higher), installed by either PAC Project 10.4002 or build 7 of the PAC Manager R10.4b installer. Wireless versions are not affected by this issue:
    • SNAP-PAC-R1
    • SNAP-PAC-R1-B
    • SNAP-PAC-R2
SNAP-PAC-SB1 Brain Firmware
This download contains current firmware for the SNAP-PAC-SB1 brain. Current firmware for all SNAP PAC brains and controllers is available in a single download here.
CAD 3D Drawing: SNAP-PAC-SB1 Brain
This CAD file contains a 3-dimensional drawing of the SNAP-PAC-SB1 serial brain.
CAD Drawing: SNAP-PAC-SB1 Brain
This CAD file includes drawings for the SNAP-PAC-SB1 brain, which provides distributed control on a serial link for the SNAP PAC System.
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
Video: Using SNAP PAC System with Ethernet/ IP
A quick overview of how any device using the EtherNet/IP protocol from Allen-Bradley can communicate with Opto 22 SNAP PAC controllers and brains. More info: IO4AB
