KB55187
Published: March 1, 2007
Invalid serial port value in communication handle command successful on SNAP-PAC-S1
SNAP-PAC-S1 Controller Firmware
Problem was introduced in version: R7.1a
Problem is fixed in version: R8.0a
An ioControl communication handle with a reference to an invalid serial port returns a successful status code when used with a communication handle command on a SNAP-PAC-S1 controller.
The following sample OptoScript code returns a status value of 0 (successful) instead of β10. Note the incorrect port value of 30000. Valid port values are 0 and 1:
SetCommunicationHandleValue(βser:30000,9600,n,8,1β,SerialPort);
NStatus = OpenOutgoingCommunication(SerialPort);
Copyright Β© 2026 Opto 22. All rights reserved.
