KB57146
Published: May 1, 2007
Trigger based historic logging may record data once instead of using stop trigger conditions
Problem was discovered in version: R8.0d
Problem is fixed in version: R8.0e
A historic log set up to start logging based on a trigger may only log data once, even though the Stop Trigger or the Number of samples conditions are not met and logging should continue to occur.
