KB81384
Published: December 11, 2023
Inconsistent Pointer Table values in PAC Control Watch Windows
PAC Control Basic
PAC Control Professional
All versions
When you add a single index (or element) or a range of elements of a pointer table to a Watch Window in PAC Control, the values may not consistently show or update in the Watch Window.
When adding elements of a pointer table to a Watch Window, select All instead of a single index or range of the table.
