KB83011
Published: December 13, 2013
PAC Display Runtime Historic Log may log too many entries when start trigger and number of samples are used
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.3c
If a PAC Display historic log is configured with a start trigger and number of samples, PAC Display may continue logging as long as the start trigger is in the triggered state, even after the number of samples has been reached.
If the start trigger reverts to a non-triggered state (perhaps from the notification), this issue doesn't occur. It occurs only when the start trigger remains in the triggered state.
