KB83290
Published: December 4, 2013
Internet Explorer 10 does not display groov properly
groov running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GROOV-SVR-WIN, GROOV-SVR-WIN-SNAP
All versions of groov.
In Internet Explorer 10, groov View and Build do not display correctly and appear to be broken.
Opto 22 recommends users follow these steps:
- Open Internet Explorer 10.
- If the menu bar is not already showing, right-click anywhere in the top border of the browser and select the Menu bar option.
- Open the Tools menu, and make sure that Compatibility View is not selected.
- Select Tools > Compatibility View settings.
- In the Compatibility View Settings dialog box, make sure that no groov IP addresses or hostnames are listed under “Websites you’ve added to Compatibility View.”
- Also, make sure that the compatibility options at the bottom of the dialog box are not checked.
- Click Close.
