KB85021
Published: August 28, 2015
groov default SSL certificate uses an older digest
GROOV-SVR-WIN-BASE
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: R3.0b and lower
Problem is fixed in version: For groov Server: R3.0c
Problem is fixed in version: For groov Box: groov Admin 42
In the groov Box and groov Server for Windows, the default certificate is generated using an older digest (SHA1). The most recent versions of web browsers use a newer digest. This issue could affect your ability to send email from groov.
