KB85038
Published: December 10, 2015
On SNAP PAC controllers, persistent variables aren't retained when using background downloading
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects: Firmware R9.4b and higher
If a PAC Control strategy with persistent variables is sent to the controller using background downloading, all persistent variable values are cleared.
This issue does not affect strategies downloaded normally (that is, without background downloading).
Use the Normal download mode, or use a firmware version lower than R9.4b.
