KB85756
Published: April 29, 2016
groov View shows yellow triangle "trying to connect" error on gadget with Data Simulator tag
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R3.1a and possibly previous versions
R3.1b
If you use Data Simulator tags with a Level Indicator gadget to build a page in groov Build and then switch to groov View, you see yellow triangles flash approximately 10-12 seconds after the page loads.
The yellow triangles indicate that groov is trying to connect to the controller or server, but connection delays should not occur for Data Simulator tags.
