KB86282
Published: October 3, 2016
groov may become unresponsive or crash, and downloading system logs may result in zero byte files
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1-SNAP
GROOV-AR1
GROOV-SVR-WIN-SNAP
GROOV-SVR-WIN
Problem was introduced in version: R3.2a
Problem is fixed in version: R3.2b
Log databases in groov 3.2a were inadvertently allowed to grow unchecked. As a result, the file system eventually fills up with log data, and groov runs out of memory, causing these possible symptoms, which can occur independently of each other:
- Attempts to download system logs may result in a long wait for the download, followed by a 0 byte file.
- Groov may become unresponsive or unreachable, or it may crash.
If your groov system does a lot of logging, this issue may occur more quickly.
On groov Server for Windows, you can clear out the log database by stopping groov and deleting C:\Program Files (x86)\Opto22\groov\logs.db.
No workaround exists for a groov Box.
