KB86332
Published: November 16, 2016
groov Image Library takes long time to load images and can cause groov to appear to freeze
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.1a and higher
If you have a large number of images (especially GIFs) in your groov Image Library, the library can take an unusually long time to load, and groov may appear to be frozen.
